URL address with and without parameter
Faced with the need to be indexed by search engines addresses with parameters, example:
domainname.com/VA/2464324/ one = parameter1 parameter2 & two =?
Who indexed pages domainname.com/VA/2464324/
I basically have two questions, links to the parameters generally fall in the index?
Can I make the search engines give preference to links with parameters?
Is it important that both addresses should have the same content?
What do you advise?
Thank you!
PS can transfer parameters in the link is something that I know can be done. Is there anything that can be done differently?
