when i try to log in now i get this — Fatal error: Call to undefined method Piwik_Url::getLocalOrigins() in /home1/connerou/public_html/piwik/core/Nonce.php on line 83
I’m getting the same thing. Updated 2 installations in tandem (using the auto-method), and they both blew up. Frustrating.
i have the same problem
Sorry for the bug, we re-packaged 0.9 - it should now work - can you please try and confirm? Thanks!
I have the same problem, now downloading new package.
only core Directory new upload or all files
only core/Nonce.php
thx it works
I still have the same problem, I reloaded the whole package. how do I just do core/Nonce.php [size=18pt]Got it to work now thanks!!![/size] style_emoticons/<#EMO_DIR#>/biggrin.gif
For those of you with the bug, simply replace core/Nonce.php with this version: http://dev.piwik.org/trac/export/2889/trunk/core/Nonce.php
Back up and running. Thanks guys!
The problem has been fixed, thanks.
