Hi, I run piwik on multiple sites, but on one the upgrade failed and I couldn’t find anything in the log files.
It failed during db update and I’m looking for ways to do the upgrade manually. I see that the db contains some data from 2010, but everything from 2011 is gone.
On the upgrade screen there were some SQL that could be run, but I can’t find it on this site. There should be something about this in the upgrade documentation I think.
When I run the update command manually from command line I only get a redirect.
php index.php – “module=CoreUpdater”
Status: 302 Moved Temporarily
X-Powered-By: PHP/5.2.13
Content-type: text/html
Can someone please advice me on how I can restore the data? Would it be easiest to do a db rollback or is this upgrade savable.
Thank you!
