I updated from 1.8.2 to 1.9.2 and everything looked good while upgrading. Then I logged into my backend and see these error messages all over the place. see attachment
After uploading the new files I replaced the config and the global.ini with my old config and global.ini. Not sure if this can be a problem or not.
Can you please help me to get it installed or updated correctly?
Looking forward to your help and answers.
Regards,
Sammy83
