Unintuitive results for segmentation entryPageUrl vs pageUrl
Setup
Piwik version: keeping nicely up-to-date 2.15.0
Tested
Segmentation entryPageUrl vs pageUrl
  • piwik/?module=API&method=API.get&columns=nb_pageviews,nb_uniq_pageviews&period=year&format=JSON&date=2015-12-14&idSite=2&token_auth=…&segment=pageUrl=@11234/LRT-1478
  • piwik/?module=API&method=API.get&columns=nb_pageviews,nb_uniq_pageviews&period=month&format=JSON&date=2015-12-14&idSite=2&token_auth=…&segment=entryPageUrl=@11234/LRT-1478
Results
  • segment=pageUrl = { nb_pageviews: 1776, nb_uniq_pageviews: 1296 }
  • segment=entryPageUrl = { nb_pageviews: 2321, nb_uniq_pageviews: 1654 }
Expected
  • count(entryPageUrl) <= count(pageUrl )
Why do you get more hits when segmenting according to entryPageUrl - is it a feature?
(The same happens for other periods e.g., month)
Hi @vidiecan
please try again with our latest PIwik 2.16.0-b1 and if you still have the issue, create a bug report @ Issues · matomo-org/piwik · GitHub
we will investigate as this is not normal!
