Thanks - I ran the SQL update commands from phpmyadmin and now it Works. THANKS
Commands executes:
Note: if you manually execute these queries, it is expected that some of them fail. In this case, simply ignore the errors, and run the next ones in the list.
ALTER TABLE piwik_logger_message ADD COLUMN tag VARCHAR(50) NULL AFTER idlogger_message;
ALTER TABLE piwik_logger_message ADD COLUMN level TINYINT AFTER timestamp;
ALTER TABLE piwik_logger_message MODIFY level VARCHAR(16) NULL;
UPDATE `piwik_archive_numeric_2012_01` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2012_10` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2012_11` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2012_12` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_01` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_02` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_03` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_04` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_05` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_06` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_07` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_08` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_09` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_10` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_11` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2013_12` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2014_01` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_numeric_2014_02` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2012_01` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2012_10` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2012_11` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2012_12` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_01` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_02` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_03` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_04` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_05` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_06` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_07` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_08` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_09` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_10` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_11` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2013_12` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2014_01` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_archive_blob_2014_02` SET `name`=REPLACE(`name`, 'Referers_', 'Referrers_') WHERE `name` LIKE 'Referers_%';
UPDATE `piwik_segment` SET `definition`=REPLACE(`definition`, 'referer', 'referrer') WHERE `definition` LIKE '%referer%';
UPDATE `piwik_report` SET `reports`=REPLACE(`reports`, 'Referer', 'Referrer') WHERE `reports` LIKE '%Referer%';
UPDATE `piwik_user_dashboard` SET `layout`=REPLACE(`layout`, 'Referer', 'Referrer') WHERE `layout` LIKE '%Referer%';
