Undefined index in Dashboard
i have a new Installation of Piwik-Version 2.12.0, PHP Version 5.6.5, mySQL-Version 5.5.
When i go to dashboard, i got an lot of warnings like this:
WARNING: D:\wwwroot\infosys\piwik\plugins\PrivacyManager\PrivacyManager.php(221): Notice - Undefined index: delete_reports_keep_month_reports
WARNING: D:\wwwroot\infosys\piwik\plugins\PrivacyManager\PrivacyManager.php(221): Notice - Undefined index: delete_reports_keep_week_reports
WARNING: D:\wwwroot\infosys\piwik\plugins\PrivacyManager\PrivacyManager.php(221): Notice - Undefined index: delete_reports_keep_year_reports
etc.
When i go to the menu Administration, Settings, Privacy, i got an error message like this, probably of the same reason like above:
Key “delete_logs_enable” for array with keys “delete_logs_enable, delete_logs_schedule_lowest_interval, delete_logs_older_than, delete_logs_max_rows_per_query, enable_auto_database_size_estimate, delete_reports_enable, delete_reports_older_than, delete_reports_keep_basic_metrics, delete_reports_keep_day_reports, delete_reports_keep_week_reports, delete_reports_keep_month_reports, delete_reports_keep_year_reports, delete_reports_keep_range_reports, delete_reports_keep_segment_reports” does not exist in “@PrivacyManager/privacySettings.twig” at line 111
What can i do to solve this problems ?
Greetings
Lars Vogelmann
Hi Lars,
  1. Is your Administration > System check all green?
  2. Can you try to reupload the file config/global.ini.php
Hi Matt,
into Administration -> System is all green.
I have only one version of the file config/global.ini.php, where was created by the installation.
Cheers
Lars
