It works without any issue if I use Recovered keys. But using usual authentication it will not work. How to execute using Linux command
as you posted execute PHP from a commandline on Windows.
I have disabled Google Authenticator and enabled again. Numbers are not detected as it seems Matomo has any connection to the timestamp inside Google Authenticator. How to manage this as I see I have Github inside Google Authenticator. Is it Matomo inside this app or some settings prevent the same numbers Sync. Please reply if this is a bug inside Matomo.
