Tutorial & help for newbie
Hello guys,
I am newbie with the PIWIK application. For my work, I need develop a new plugin of specific statistic.
Do you have a tutorial in step to step, for use a VisitsSummary API ? for create a new plug-in ?
When I reading the referentiel, I have difficulty understand the operation of Hook API .
Do you have some informations ?
Thanks for your help.
Djik
I wrote an article that describes how to write a Piwik Plugin: How to write a Piwik Plugin
Let me know if you need any help or don’t understand something in the article.
Thanks Fabian. This tutorial helped me advance ^ ^
I have nevertheless different questions about the operation of Piwik:
  • How can we organize a plugin directory Piwik? There is there any directories mandatory? We can add their own directory?
  • Can you connect to other tables in that piwik database dedicated? in another database?
  • In some existing plugins api.php file exists. What is it?
  • What are the possibilities of function install ()? Can be created to create tables? Can we move (or create) files?
  • How do I use the library to generate the graphs in Piwik?
thank you
Djik
