Tutorial for merge 2 site IDS data (Working method)
In this example we have two site ids,
In site id 25 we only have data from 1 march 2016 up to 14 September 2022 and in site id 2, we have data from 15 September 2022 until today.
The idea is to merge all the data in site id 2.
You must run this sql query on the database of your matomo installation, but remember to change the date range and ids of sites you want to merge first.
I would like to ask the Matomo team to implement this option.
delimiter //
CREATE PROCEDURE merge_sites(
    IN id_old INT,
    IN id_new INT,
    IN month_start VARCHAR(7),
    IN month_end VARCHAR(7),
    IN day_end INT
BEGIN
    DECLARE done BOOL DEFAULT FALSE;
    DECLARE tablename CHAR(255);
    DECLARE cur_tablename CURSOR FOR
        SELECT TABLE_NAME
        FROM INFORMATION_SCHEMA.TABLES
        WHERE (
            TABLE_NAME >= CONCAT("matomo_archive_numeric_", REPLACE(month_start, '-', '_'))
            AND TABLE_NAME <= CONCAT("matomo_archive_numeric_", REPLACE(month_end, '-', '_'))
        ) OR (
            TABLE_NAME >= CONCAT("matomo_archive_blob_", REPLACE(month_start, '-', '_'))
            AND TABLE_NAME <= CONCAT("matomo_archive_blob_", REPLACE(month_end, '-', '_'))
    DECLARE CONTINUE HANDLER FOR NOT FOUND SET done = TRUE;
    DECLARE CONTINUE HANDLER FOR SQLEXCEPTION BEGIN END;
    OPEN cur_tablename;
    myloop: WHILE NOT done DO
        FETCH cur_tablename INTO tablename;
        IF NOT done THEN
            SET @sql = CONCAT(
                'UPDATE ', tablename,
                ' SET idsite = ', id_new,
                ' WHERE idsite = ', id_old,
                ' AND date1 <= \'', DATE_FORMAT(
                    STR_TO_DATE(
                        CONCAT(YEAR(DATE_ADD(NOW(), INTERVAL -1 MONTH)), '-', MONTH(DATE_ADD(NOW(), INTERVAL -1 MONTH)), '-', day_end),
                        '%Y-%m-%d'
            PREPARE stmt FROM @sql;
            EXECUTE stmt;
            DEALLOCATE PREPARE stmt;
        END IF;
    END WHILE;
    CLOSE cur_tablename;
    UPDATE matomo_site
    SET ts_created = TIMESTAMP(CONCAT(month_start, '-01 00:00:00.000'))
    WHERE idsite = id_new;
    UPDATE matomo_log_link_visit_action
    SET idsite = id_new
    WHERE idsite = id_old;
    UPDATE matomo_log_visit
    SET idsite = id_new
    UPDATE matomo_log_conversion
    SET idsite = id_new
    UPDATE matomo_report
    SET idsite = id_new
    UPDATE matomo_report_numeric
    SET idsite = id_new
    UPDATE matomo_report_blob
    SET idsite = id_new
    UPDATE matomo_sequence
    SET idsite = id_new
    UPDATE matomo_session
    SET idsite = id_new
    UPDATE matomo_site_setting
    SET idsite = id_new
    UPDATE matomo_site_url
    SET idsite = id_new
    UPDATE matomo_tracking_goal
    SET idsite = id_new
    UPDATE matomo_user
    SET idsite = id_new
    UPDATE matomo_user_dashboard
    SET idsite = id_new
END;
DELIMITER ;
CALL merge_sites(
    25, -- source site id
    2, -- target site id
    '2016-03', -- start month
    '2022-09', -- end month
    14 -- day_end
With this query the properties were merged well, so the old ID could now be removed.
But before do that, the blob_archive and blob_numeric tables would still need to be changed in the database, as they still retain the old ID
For this we would have to make the same query for all years and months, except for the month of September 2022, since in our case it had half a month in one site id and another half a month in the other one.
This is the query for that year:
UPDATE matomo_archive_blob_2022_01 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_02 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_03 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_04 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_05 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_06 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_07 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_08 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_blob_2022_09 SET idsite = 2 WHERE idsite = 25 AND date1 <= ‘2022-09-14’;
UPDATE matomo_archive_numeric_2022_01 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_02 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_03 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_04 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_05 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_06 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_07 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_08 SET idsite = 2 WHERE idsite = 25;
UPDATE matomo_archive_numeric_2022_09 SET idsite = 2 WHERE idsite = 25 AND date1 <= ‘2022-09-14’;
If you find a better way to achieve this, I would appreciate your comments.
