I was updating today Serbian translation for Piwik 1.1 and all of the sudden I was unable to see flash components of Piwik. Tables are displayed but no graphs and vidgets. Piwik says Displaying Graphs in Piwik requires Flash >= 10.0.0 but I have it installed, it worked this morning normally. Even don’t have drop down list to change display language I changed language for admin to en manually in mysql table piwik_user_language, language changed to English but still no flash.
Can it be that some broken translation string is cause of this?
I have Piwik 1.0 installed on other site (where I didn’t changed language files yet) and everything is displayed just fine so I assume it is not browser related problem.
See attached screenshots. jQuery claims not to be loading on the later, but when I try to directly access the link provided in the source, the file loads just fine. Not sure what’s going on there.
If you would like to debug it some more, I can give you a login to the instance I have setup where this is happening… it doesn’t bother me though, I’ve never used that plugin before so disabling it is good enough for me.
