it seems to me that class piwik_download is currently not working. The actions are all tracked as normal site view but not as download as it should be!
can anybody help?
thanks!
can anybody help?
thanks!
could you prepare a small HTML page where the problem can be reproduced?
here you go
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Titel der Webseite</title>
<!-- weitere Kopfinformationen -->
<!-- Kommentare werden im Browser nicht angezeigt. -->
</head>
<body>
<p>Inhalt der Webseite</p>
<a class="piwik_download" href="http://www.ibumedia.de" target="_blank">download</a>
<!-- Piwik -->
var pkBaseURL = (("https:" == document.location.protocol) ? "https://piwik.ibumedia.de/" : "http://piwik.ibumedia.de/");
var piwikTracker = Piwik.getTracker(pkBaseURL + "piwik.php", 44);
piwikTracker.setCustomVariable(2, 'Thessaurus', '/Technik/Gestaltung/1234567890/1234', 'page');
piwikTracker.trackPageView();
</script><noscript><p><img src="http://piwik.ibumedia.de/piwik.php?idsite=44" style="border:0" alt="" /></p></noscript>
<!-- End Piwik Tracking Code -->
</body>
</html>
If I click on the link the view will be recorded but no download!
If you link to an external domain, the click will be counted as “Outlink” — is this the behavior you are observing (that the click is tracked as outlink) ?
Correct. The link is tracked as outlink. But I thought it will be tracked as download if it has the css class “piwik_download”
Good suggestion! I created a ticket Piwik.js: when using class="piwik_download" on an outlink, it should track a download and not an outlink · Issue #3292 · matomo-org/matomo · GitHub
ok if that isn’t the already intended behavior of the css class “piwik_download” then the documentation is misleading
