Tracker-proxy and optout
#1
Hi everyone,
is there a possibility to use tracker-proxy and any kind of optout cookie (lokal piwik_ignore.tpl)?
My piwikserver is placed into a intranet. All webservers are located in internet and haven’t directly
access to piwik.
Piwik and tracker-proxy works fine, but our visitiors need the opportuny to disagree tracking.
Thanks Adolar
Entrys in config.ini.php
[General]
assume_secure_protocol = 1
proxy_client_headers[] = HTTP_X_FORWARDED_FOR
proxy_host_headers[] = HTTP_X_FORWARDED_HOST
[proxy]
host = "my.outgoing.proxy.de"
port = PortNr…
my local “piwik_ignore.tpl” work’s fine and generate the “piwik_ignore” cookie. But whatever, piwik tracking is active…
piwik_ignore.tpl:
<input type="checkbox" value="ignore_me" name="ignore" onclick="changeIgnoreState()" id="ignore">
<label style="font-family: Arial;font-size: 85%;" for="ignore"><strong>Besuche von dieser Website mit diesem Browser von der Websiteanalyse mittels Piwik ausschlie&szlig;en</strong></label>
    {literal}
    if (document.cookie) {
        a = document.cookie;
        if (a.indexOf('piwik_ignore') == -1)
            document.getElementById("ignore").checked = false;
        else
            document.getElementById("ignore").checked = true;
    function changeIgnoreState() {
        b = new Date();
        if (document.getElementById("ignore").checked == false) {
            c = new Date(b.getTime() - 1000*60*60*24*365);
            document.cookie = 'piwik_ignore=; expires='+c.toGMTString()+';';
        else {
            c = new Date(b.getTime() + 1000*60*60*24*365*1000);
        location.reload();
    {/literal}
</script>
#2
Please check this alternative and separate and independently Matomo OptOut:
https://www.penultima.de/opt/matomo.php
(Lukas Winkler) #3
@adolar
You can see the current status here:
The latest version at least supports forwarding the DNT header.
