I just want to make sure it is worth to write the mail. Cause the last time I wrote to them I just received the answer any help would be available after I am in a plan.
The advanced campaign reporting plugin looks nice but doesn’t work as promised, at least in my Piwik. I asked for support but it is only available if you subscribe a plan.
The new campaings report does not replace the old one in the Referrers->Campaigns tab.
There are diferences in the data reported betwen this plugin and the old one. I attach two files showing the diferences.
[attachment 1940 old_report.png]
[attachment 1941 new_report.png]
But the point 2 is still wrong. Also, the numbers that appears in Referrers->Campaigns tab is different that the ones that apperar in the overview tab.
I have find another issue. In the old Campaigning system, the variables used are pk_campaign and pk_kwd, but in the advanced they are pk_campaign, pk_keyword,… Thats means the keyword is not compatible between versions. Could it be made compatible so any of the variable names could be used?
