Is it possible to track goals per pages on Matomo ? Seems I can only get a global view of the conversions but not know where it occured.
Thanks in advance for your answer,
All the best.
All the best.
Yes, I would also like to know if there is any way (without using the premium Custom Reports?) to get more information about on which page (or which Content) a conversion or other event occurred.
Apparently the only way is to use the Premium Custom Reports, we already bought it, now I have to figure out how to configure it…
@nicomatomo , probably doing like that (not tested):
Note also that if you want to use Page title as Dimension, it would probably not work. To be able to use such dimension, I had to create my own Page title as Custom Action dimension and use it in the custom reports…
Hi Philippe,
Yes I managed to set my own reports, thanks for your help.
Nicolas
