SURF2016
(HizkiaWeerd)
#1
Hi all,
We’re trying to log the clicks on the 4 banners on our website
Now we’ve added some trackevent JS to the banners:
for example:
a onclick="_paq.push([‘trackEvent’, ‘CategoryName’, ‘ActionName’, ‘ActionValue’]);"
We’de expect that the tracked events would appear on the PIWIK \ ACTIONS \ EVENTS view, but there’s nothing to show in the events section :-(.
Any help would be appreciated.
kind regards,
SURF
Valdhor
(Steve Mercer)
#2
The small snippet of code you provided looks right.
Can you provide a bit more code?
What version of Piwik are you running?
Are there any JS errors (Try Firebug).
SURF2016
(HizkiaWeerd)
#3
Hi Valdhor,
I’ve now tried to gather the tracking informatie with campaigns instead of tracking events
but still like to use Javascript instead.
version
Piwik 2.16.2
Firebug
Couldn’t find any errors while using firebug
matthieu
(Matthieu Aubry)
#4
Even tracking should work. Do they appear in Visitors > Visitor log ?
SURF2016
(HizkiaWeerd)
#5
After reading a great e-book: https://www.theinternetacademy.nl/content/uploads/materiaal/piwik-ebook.pdf we found the right solution for our wish:
Tracking with events was a rather difficult task and didn’t seem to work as expected
Solved it now by adding the "_paq.push([‘trackVisibleContentImpressions’]);"element to the tracking code and added classes to the banners.
example banner code:
<p><a class="piwikTrackContent" href="site-I-want-to-link-to.html"><img title="banner1" src="https://test.mysite.nl/media/wysiwyg/Banners/mysite-banner-bigbanner.png" alt="e-commerce-banner" data-content-name="werkt" /></a></p>
Result in PIWIK:
> <!-- Piwik -->
> <script type="text/javascript">
> var _paq = _paq || [];
> _paq.push(['trackPageView']);
> _paq.push(['enableLinkTracking']);
> _paq.push(['trackVisibleContentImpressions']);
> (function() {
> var u="//piwik.mysite.nl/";
> _paq.push(['setTrackerUrl', u+'piwik.php']);
> _paq.push(['setSiteId', '3']);
> var d=document, g=d.createElement('script'), s=d.getElementsByTagName('script')[0];
> g.type='text/javascript'; g.async=true; g.defer=true; g.src=u+'piwik.js'; s.parentNode.insertBefore(g,s);
> </script>
> <noscript><p><img src="//piwik.mysite.nl/piwik.php?idsite=3" style="border:0;" alt="" /></p></noscript>
> <!-- End Piwik Code -->
