The Method 'invalidateArchivedReports' does not exist
I want to try to invalidate log entries by calling “invalidateArchivedReports” (see How do I record tracking data in the past, and tell Piwik to invalidate and re-process the past reports? - Analytics Platform - Matomo), but I get this error message (the translation is “The method ‘invalidateArchivedReports’ doesnot exist or is not available in the module ‘\Piwik\Plugins\CoreAdminHome\API’”):
<result>
    <error message="Die Methode 'invalidateArchivedReports' existiert nicht oder ist im Modul '\Piwik\Plugins\CoreAdminHome\API' nicht verfügbar."/>
</result>
The URL i use to call it is like this:
http://test.invalid/?module=API&method=CoreAdminHome.invalidateArchivedReports&idSites=1&dates=2015-07-16&token_auth=1234567890
I’m using Piwik 2.14.1.
Any idea why it doesn’t work?
Best regards!
Stefan Wagner
Hi Stefan
Please check your are using a token_auth for a Super User in Piwik.
Hello Matt,
thanks that was the fix for the problem (but the error message could be a little bit more helpful :wink:
Did this change in one of the last releases? I thought that it worked when I implemented ist for the first time…
Best regard!
Stefan
Hi there,
Yes we could display better message! Could you suggest this in a new issue at: Issues · matomo-org/piwik · GitHub ?
Btw: What happened is that you changed your password which changed your token_auth
