Hi!
in /var/log/messages in our piwik-server I get a message every time, the archive-script is running:
suhosin[5416]: ALERT - script tried to increase memory_limit to 805306368 bytes which is above the allowed value (attacker ‘REMOTE_ADDR not set’, file ‘/var/lib/piwik/core/SettingsServer.php’, line 162)
I know, I can get rid of this alert, if I set the memory_limit in suhosin.ini up to 768M, which is the value piwik uses.
My question is, is this Suhosin-Message only a warning and Suhosin does or blocks nothing. Or is it an error-message and suhosin blocks the “increase-memory-request” of the piwik-script?
The archive-script runs smoothly, as far as I can tell.
Is there any problem for the piwik-archiving if I ignore the alert-message?
