There is an error. Please report the message (Piwik 1.10) and full backtrace in the Piwik forums (please do a Search first as it might have been reported already!).
Strict Notice: Only variables should be passed by reference in /var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Menu/Abstract.php on line 61
Backtrace -->
#0 Piwik_ErrorHandler(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Menu/Abstract.php:61]
#1 Piwik_Menu_Abstract->add(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Menu/Top.php:99]
#2 Piwik_AddTopMenu(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/plugins/API/API.php:42]
#3 Piwik_API->addTopMenu(…) called at [:]
#4 call_user_func_array(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/libs/Event/Dispatcher.php:284]
#5 Event_Dispatcher->postNotification(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/PluginsManager.php:723]
#6 Piwik_PostEvent(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Menu/Top.php:64]
#7 Piwik_Menu_Top->get(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Menu/Top.php:77]
#8 Piwik_GetTopMenu(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Controller.php:473]
#9 Piwik_Controller->setBasicVariablesView(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/plugins/Login/Controller.php:98]
#10 Piwik_Login_Controller->configureView(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/plugins/Login/Controller.php:86]
#11 Piwik_Login_Controller->login(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/plugins/Login/Controller.php:46]
#12 Piwik_Login_Controller->index(…) called at [:]
#13 call_user_func_array(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/FrontController.php:138]
#14 Piwik_FrontController->dispatch(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/Controller.php:723]
#15 Piwik_Controller->redirectToIndex(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/plugins/CoreHome/Controller.php:42]
#16 Piwik_CoreHome_Controller->redirectToCoreHomeIndex(…) called at [:]
#17 call_user_func_array(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/core/FrontController.php:138]
#18 Piwik_FrontController->dispatch(…) called at [/var/virtual/xxxxxxxxxx/htmlroot/piwik/index.php:53]
