I performed a clean install of the new Piwik version today. I deleted everything and started with refresh databases. The installation showed 100% checkmarks with no issues with the file system and otherwise. For a couple of months now, I have had no luck showing any data for visits to my web site. Whether I go to the Visitor tab or to the calendar, nothing shows up. Any pointers on this? I host with Hostgator if that makes any difference?
Thank you for your help in advance.
Cam
