I installed Matomo on my Nginx server and used the Nginx config provided by Matomo to set up the host. When I visit the login page for the Matomo dashboard, all static assets are being blocked by Chrome. If I open the same page in incognito mode or another browser, all works fine.
Yes, all requests are on the same domain with HTTPS. When I try to open these blocked assets in a new tab, they are loading perfectly without any errors.
“blocked” sounds a lot as if some browser extension is telling the browser to not make those requests.
Is it possible that you have an adblocker or something like this enabled with an overly wide rule that matches those requests?
Maybe it’s a default setting from Chrome. But I don’t have installed anything manually.
On another server, I have running another Matomo installation with Matomo version 4.4.1 and Apache as web server. This installation is running without any problem in the same browser.
At least for me with Chromium 93.0.4577.82 (and a fresh browser profile) everything is loading fine. So there has to be something in your Chrome setup (or maybe you have another software like an anti-virus or a company firewall intercepting and blocking the request).
