when i am trying to install the actual version of piwik on my webserver, i always get following error message:
Error while trying to connect to the database server:
SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-13' at line 1
the step ‘systemcheck’ at the start of piwik installation shows no problems.
