The charset is problematic in my pdf reports.
Accents are not displayed correctly:
How can I solve this please ?
[quote=jOoL]
How can I solve this please ?[/quote]
I am getting the same problem the the charset. I wold love to know the answer. Thanks, Byron.
Hi
is it new in 1.2 , or did you have the problem in 1.1.1 as well?
[quote=matt]
Hi
is it new in 1.2 , or did you have the problem in 1.1.1 as well?[/quote]
Hi, I had the problem in 1.1.1 as well.
What charset is your website using? can you put your page URL with some buggy name so I can see the request to piwik?
[quote=matt]
What charset is your website using? [/quote]
iso-8859-1"
[quote=matt]
can you put your page URL with some buggy name so I can see the request to piwik?[/quote]
http://www.cailler-electromenager.ch/contacts.html?message=S�che-linge+Miele%2C+s�rie+4000+-+T+48-39+C+CH#contact
Thanks
jOoL
i’ll open a ticket. I don’t think we handled charset/encoding conversion for page titles. (We do for search engine keywords.)
Thanks a lot !
This should now be fixed in http://dev.piwik.org/trac/changeset/4080
Note: it won’t convert page titles already recorded/archived.
(Edit: That didn’t fix it. Ticket sanitizeInputValue() - improvements · Issue #2185 · matomo-org/matomo · GitHub has been re-opened for reinvestigation.)
JOol: are you using the PiwikTracker class to track those contact URLs?
I use standard JS script:
Oh, I see.
We can’t fix this because piwik.js already encodes the action name (using %xx for special chars). Your example results in double encoding because you’re passing in a URL that’s already encoded.
You should use unescape() or decodeURIComponent() first, e.g.,
// depending on the URL:
piwikTracker.setDocumentTitle(unescape( url ));
// or
piwikTracker.setDocumentTitle(decodeURIComponent( url ));
These forms would work:
// \x - followed by hexits
piwikTracker.setDocumentTitle("/contacts.html?message=S\xE8chelinge+Miele\x2C+s\xE9rie+4000+-+T+48-39+C+CH" ) ;
// html entity code , &# decimal ;
piwikTracker.setDocumentTitle("/contacts.html?message=Sèche-linge+Miele,+s&#%233;rie+4000+-+T+48-39+C+CH" ) ;
// or UTF-8
piwikTracker.setDocumentTitle("/contacts.html?message=Sèche-linge+Miele,+série+4000+-+T+48-39+C+CH" );
Thanks I used
and it works now.
Not the other solution.
Thanks a lot!
