i’ve updated from Piwik 1.8.2. (I think) to Piwik 1.8.3. with the “The One-Click Piwik Update” ( http://piwik.org/update/#oneclick ).
Everything went fine, but I have a main problem: I can connect to the interface as usual, but nothing works in the dashboard.
If I reload I get the same result, and if I try to restore the dashboard, to erase it or to create an other I get an error and nothing happens.
I can access to different informations individually, as the recap’ of the visitors, the titles of the entry pages, and so on.
But every time I click on a “+” to get more informations (as the detail of the files downloaded), I get an endless “loading” :
Ps : In /piwik/config/global.ini.php, I’ve changed before the update " session_save_handler = files" by “session_save_handler = dbtable” following the suggestion made at http://forum.ovh.com/showthread.php?t=76808&page=6
But this modification was erased during the update, why don’t you keep this kind of modification?
can you try to delete your browser cache and try again ? or try with a different browser?
All modifications must be made in the config/config.ini.php ie. you can copy paste the setting in the config.ini.php file, this one will not be modified in the update.
Oh, I should have mentionned that : I’ve tried with Iceweasel 10.0.6, Chromium 20.0.1132.57, Opera 12.02, each time with the browser cache empty. My O.S. is debian, but I’ve tried with ubuntu and windows, too.
Ah, ok, I didn’t know that, thanks.
301 - moved permanently
[2012-09-02 14:53:34] [cb60223b] [5.58 Mb] NOTE: if you execute this script at least once per hour (or more often) in a crontab, you may disable 'Browser trigger archiving' in Piwik UI > Settings > General Settings.
[2012-09-02 14:53:34] [cb60223b] [5.58 Mb] see doc at: http://piwik.org/docs/setup-auto-archiving/
[2012-09-02 14:53:34] [cb60223b] [5.59 Mb] ---------------------------
[2012-09-02 14:53:34] [cb60223b] [5.58 Mb] INIT
[2012-09-02 14:53:34] [cb60223b] [5.59 Mb] Querying Piwik API at: http://mydomain.org/path/to/piwik/misc/cron/../../index.php
[2012-09-02 14:53:34] [cb60223b] [5.59 Mb] Running as Super User: admin
[2012-09-02 14:53:34] [cb60223b] [5.68 Mb] ERROR: The Piwik URL http://mydomain.org/path/to/piwik/misc/cron/../../index.php does not seem to be pointing to a Piwik server. Response was '
Moved Permanently
The document has moved here [ http://mydomain.org/path/to/piwik/?module=API&method=API.getDefaultMetricTranslations&format=php&trigger=archivephp
Fatal error: The Piwik URL http://mydomain.org/path/to/piwik/misc/cron/../../index.php does not seem to be pointing to a Piwik server. Response was '
Moved Permanently
The document has moved here [ http://mydomain.org/path/to/piwik/?module=API&method=API.getDefaultMetricTranslations&format=php&trigger=archivephp].
'. in /homez.541/micrlab/www/tech/piwik/misc/cron/archive.php on line 556
I erased my Piwik folder, updated the files anew, configured Piwik as it was the first time I use it, told to use again my old Database, but I get exactly the same strange behaviour…
Could my .htaccess be responsible?
Ps : I think I noticed a small bug : if I go to http://mydomain.org/path/to/piwik/misc/cron/archive.php, I have a message starting with
"You must specify the Super User token_auth as a parameter to this script, eg. &token_auth=XYZ if you wish to run this script through the browser."
But the url is not …misc/cron/archive.php&token_auth=XYZ, but …misc/cron/archive.php?token_auth=XYZ
