I would like to create a single logon experience for my CMS and PIWIK. I plan to have the user databases exactly the same (and eventually shared/linked somehow.) I’m not sure what the best way is to do this but I had thought that I may be able to write a plugin in the CMS that will do the CMS logon then pass the login details over to piwik.
I would like to pass the login details in an array to the below function as defined in login.php
* Authenticate user and initializes the session.
* Listens to Login.initSession hook.
* @param Piwik_Event_Notification $notification
function initSession($notification)
Is anyone able to advise me how I can get pass the array from the CMS to this function? Or if it is possible to interface the two systems at the back-end.
Cheers
