How do you get the userid using JavaScript in SharePoint 2013?
I am using/testing your FREE Piwik self-hosted application for SharePoint 2013.
I applied the JavaScript as instructed to my masterpage as instructed and I am getting data.
However, I am unable to acquire the User information (userid).
I’ve tried using “_spPageContextInfo.userId”, but on the masterpage I need to wait for the “sp.js” to load first.
I’ve tried this:
var _paq = _paq || [];
ExecuteOrDelayUntilScriptLoaded(getPageContextInfo, "sp.js");
function getPageContextInfo() {
var userId = _spPageContextInfo.userId;
_paq.push(['setUserId', userId]);
_paq.push(['setDocumentTitle', document.title]);
_paq.push(['trackPageView']);
(function() {
var u="//localhost/piwik/";
</script>
<!-- End Piwik Code -->
About your issue: I can’t help that much, but if you check the network tab of your browser, you can see the request to piwik.php which is sending the data. That way you can find out if the issue is in the tracking code or if Piwik isn’t working correctly.
See my script below.
It works for me using SharePoint 2013
I borrowed the script from the REST API at the bottom of this page:
<!-- Piwik -->
ExecuteOrDelayUntilScriptLoaded(getPageContextInfo, "core.js");
/* START GET USER NAME */
var userid = _spPageContextInfo.userId; // GET USERID
var requestUri = _spPageContextInfo.webAbsoluteUrl + "/_api/web/getuserbyid(" + userid + ")";
var requestHeaders = { "accept": "application/json;odata=verbose" };
$.ajax({
url: requestUri,
contentType: "application/json;odata=verbose",
headers: requestHeaders,
success: onSuccess,
error: onError
function onSuccess(data, request) { // SUCCESS
var Logg = data.d;
var HRMIS = Logg.LoginName.split('|')[1]; // ACCOUNT LOGGED IN
var displayName = Logg.Title; // DISPLAY NAME
HRMIS = HRMIS.replace('ross\\', '' ); // REMOVE ROSS
piwikUser = displayName+' ('+HRMIS+')'; // SET PIWIK USER
piwikUser = piwikUser.toString();
_paq.push(['setUserId', piwikUser]);
function onError(error) { // ERROR
_paq.push(['setUserId', 'error']); // RECORD USER AS ERROR
/* END GET USER NAME */
// accurately measure the time spent on the last pageview of a visit
_paq.push(['enableHeartBeatTimer']);
(function() {
</script>
