setCustomData not working
Im doing a plugin that tracks some additional data to the log_visit table. But im having some trouble saving data. My trackingcode looks like this:
As seen i have an array with “tracked_userID” that is set using setCustomData. This seems to work but now the question is how to grap that data on the PHP side. I have the following:
public function getListHooksRegistered()
	return array(
		'Tracker.newVisitorInformation' => 'logUserID',
public function logUserID($notification)
$visitorInfo =& $notification->getNotificationObject();
$custom = Piwik_Common::getRequestVar(‘data’);
$visitorInfo[‘tracked_userID’] = $custom[‘tracked_UserID’];
But it seems like $custom[‘tracked_UserID’] is empty. If i try to serialize the $custom i get the following:
s:34:"{“tracked_userID”:11751}";
So how am i able to get the “tracked_userID” from the data?
BR/Sune
Hi again,
It seems that i have to replace " with real quoetes like " and then do a json_decode.
But why is this nessecery - its gonna be a “Dirty” solution.
/Sune
So know my code looks like:
	// retrieve the array of the visitors data from the notification object
	$custom = Piwik_Common::getRequestVar('data');
	//This is a diry hack - needs to be fixed!!
	$u = str_replace(""",'"',$custom);
	$s = json_decode($u,true);
	//Hack end!
	       $visitorInfo['tracked_userID'] = $s['tracked_userID'];
Sorry, adding documentation, examples, and helper functions for handling custom data is on our ToDo list…
Piwik_Common::getRequestVar sanitizes the input. So instead of str_replace(), use Piwik_Common::unsanitizeInputValue() before calling json_decode().
hi
what does ‘data’ here refers to?
when i am using it i get the following message…
The parameter ‘data’ isn’t set in the Request, and a default value wasn’t provided
[quote=Anita @ May 7 2010, 10:41 AM]hi
The parameter ‘data’ isn’t set in the Request, and a default value wasn’t provided[/quote]
Hi Anita,
‘data’ is just the name of the variable that is used in the server side(php) for the custom data that you set in the Javascript side.
For. eg, in my test.html page I am setting a custom user tracking ID
var customUserTracking = { 'uid' : '11751kiran'};
piwikTracker.setCustomData(customUserTracking);
piwikTracker.trackPageView();
In the above example, I am setting the cstom tracking data. Now in order to use the value in my php code I am going to do the following :
$myCustomData = Piwik_Common::getRequestVar('data');
$cleanData = json_decode(Piwik_Common::unsanitizeInputValue($myCustomData),true);
$this->customUserId = $cleanData['uid'];
Looks like you are not setting the data in the JS and trying to use it, that is why you are getting the error.
Hope this helps style_emoticons/<#EMO_DIR#>/smile.gif
Bests,
Kiran
hi kiran
But I have set the custom data in my tracking page.
[quote=Anita @ May 7 2010, 11:29 AM]hi kiran
But I have set the custom data in my tracking page.[/quote]
Can you share the tracking code where you are setting the value and also the php code so I can see what the problem is style_emoticons/<#EMO_DIR#>/smile.gif
hi
Tracking code: sample/index.php
and in my plugin i have added a hook in getListHooksRegistered()
‘Tracker.newVisitorInformation’ => ‘logProviderInfo’,
and in logProviderInfo()
$s = json_decode(Piwik_Common::unsanitizeInputValue($custom),true);
$visitorInfo[‘user_login_id’] = $s[‘userId’];
Is using the method logProviderInfo() in my plugin is a problem?
Looks like you are not using the $notification object in your method
Try this :
public function logProviderInfo($notification)
	$visitorInfo['user_login_id'] = $s['userId'];
hi kiran
thank you style_emoticons/<#EMO_DIR#>/smile.gif it got updated in my db…
Whenever some is logged at my website, i add a userid by setCustomData.
Can you tell me, please, how to get the live plugin to output at least a list of these userids?
I couldn’t find out how get this added into the live plugin and i even couldn’t find the customdata at the database :-/ or isn’t it stored by default?
Thanks for help
FYI, I will be working on putting ‘Visitor custom variable’ in Piwik in the next release. Keep an eye on the ticket: Custom Variables support: new JS API and new reports · Issue #1984 · matomo-org/matomo · GitHub or the next release.
