I am trying to create what should be a simple segment of visitors from the United States AND the Page URL does not contain /learning-center . However when I look at the User Log I see traffic for /learning-center. The objective is to see all visits from the US excluding those to pages under this directory. Also are segments retro active?
Hi @AlexF
I think you just don’t have users who visited ONLY pages not containing /learning-center
I think you can reach your goal using a visit custom dimension. This dimension (for example Learning center reached
) must be set (for example yes
) only if the path is reached (the visit dimension is updated only if value is set).
Then your segment would be: visitors from the 'United States' AND Learning center reached Is not 'yes'
