Hi
when I run the script “archive.php” I have the following warning message
ALERT - script tried to increase memory_limit to 134217728 bytes which is above the allowed value (attacker ‘REMOTE_ADDR not set’, file ‘/appli/projects/piwik/apache_2.2.11/htdocs/piwik/core/Piwik.php’, line 1035)
how can we modify or permit the increased memory ?
Is it normal that the data imported by python script import_logs.py are no longer visible on the portal piwik ?
although there is little data base should always pass the script archive.php
thanks for your help
