Save goal will not work when goal URL starts with "http://"
Hello!
I try to set a goal with piwik.
My goal is a cloaked URL with "pretty link plugin",
I already read in the form that I have to set up this goal as an external link, http://mydomain.net/my-custom-link
The problem is, I can not save the goal. It keeps loading nonstop, even if I refresh the page after a minute or so, the goal was not saved.
http://screencast.com/t/PS54c9diF3UW
If I try to save the goal without the http:// , that works instantly... strange...
Anyone has an idea how I can save that goal?
When you create the goal and it fails, can you check your server error log file? Maybe you will find an error there.
Otherwise could you try to look in your browser > Developer tools > Network panel, and see what error the request returns?
@matthieu Here is the screenshot. When I try to select is exactly it give me 406 error.
Can you please suggest the solution?
Anyone can help to fix the above mentioned issue i.e., 406 error in case of is exactly while creating a new goal? Please help me I am waiting for your support.
