This is a f’ing awesome project. You guys did really good. I thought it over for a couple days on which direction I should go Piwik or GA and came to the conclusion that I want to control the info and not someone else.
I downloaded this new and installed last night in literally 5 minutes. I added mine as a subdomain so I can give access to different users…anyways I found only one issue.
Under super user (since I have not created others yet) When I go to add another website…the data does not get saved to the mysql database when I hit “save”. I can go into the database itself and add the info manually via phpmyadmin and it shows in Piwik, but the save button does not save.
After further review…the green circle was not on the visible page. The page is wider than my monitor and tab order never took me to the green circle. I apologize for what appears to be a waste of time.
vipsoft - I appreciate your time in posting and the wealth of knowledge you supply to the board.
No worries. This has been a source of confusion for many. I believe Matt has implemented a fix in the upcoming 1.2 to make this more prominent / self-evident.
