Hi, I don’t know whether I should consider this as bug, but, piwik reports visits from IP 192.0.83.x. This looks like a search engine bot (see attached log). So I wonder why this is reported by Piwik? Or course, I didn’t configure Piwik to track bots.
Isn’t it WP plugin called mShots triggered from your local server which generates those “visits”?
You should then exclude it manually if so.
First of all we don’t have Word Press on our installation, second, the result of whois says :
# Query terms are ambiguous. The query is assumed to be:
# "n 192.0.83.47"
# Use "?" to get help.
# The following results may also be obtained via:
# http://whois.arin.net/rest/nets;q=192.0.83.47?showDetails=true&showARIN=false
&ext=netref2
NetRange: 192.0.64.0 - 192.0.127.255
CIDR: 192.0.64.0/18
OriginAS: AS2635
NetName: AUTOMATTIC
NetHandle: NET-192-0-64-0-1
Parent: NET-192-0-0-0-0
NetType: Direct Assignment
RegDate: 2012-11-20
Updated: 2012-11-20
Ref: http://whois.arin.net/rest/net/NET-192-0-64-0-1
OrgName: Automattic, Inc
OrgId: AUTOM-93
Address: 60 29th Street #343
City: San Francisco
StateProv: CA
PostalCode: 94110
Country: US
RegDate: 2011-10-05
Updated: 2013-11-01
Ref: http://whois.arin.net/rest/org/AUTOM-93
OrgTechHandle: NOC12276-ARIN
OrgTechName: NOC
OrgTechPhone: +1-877-273-8550
OrgTechEmail: ipadmin@automattic.com
OrgTechRef: http://whois.arin.net/rest/poc/NOC12276-ARIN
OrgAbuseHandle: ABUSE3970-ARIN
OrgAbuseName: Abuse
OrgAbusePhone: +1-877-273-8550
OrgAbuseEmail: abuse@automattic.com
OrgAbuseRef: http://whois.arin.net/rest/poc/ABUSE3970-ARIN
OrgNOCHandle: NOC12276-ARIN
OrgNOCName: NOC
OrgNOCPhone: +1-877-273-8550
OrgNOCEmail: ipadmin@automattic.com
OrgNOCRef: http://whois.arin.net/rest/poc/NOC12276-ARIN
# ARIN WHOIS data and services are subject to the Terms of Use
# available at: https://www.arin.net/whois_tou.html
