just playing around with Piwik for the first time, so sorry if my questions are nuts.
I’ve installed the script, database has been created and all looking fine. So I’ve added my website, copy&pasted the Script-Code onto every page, but it looks like the script isn’t capturing anything.
And when I copy&paste the js-code (the noscript-part) directly to my browser, the following error occurs:
Parse error: syntax error, unexpected T_STATIC, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or ‘}’ in /homepages/5/x424ffd/htdocs/piwik/libs/Event/Dispatcher.php on line 154
Not sure how you got past the Installer check for php, but it looks like you’re using php4. Your hosting provider can help you with making php5 your default.
[quote=vipsoft @ Sep 13 2009, 12:56 PM]What versions of php and piwik?
Not sure how you got past the Installer check for php, but it looks like you’re using php4. Your hosting provider can help you with making php5 your default.[/quote]
Next problem I have: I can’t add or delete widgets to the dashboard. Looks like Piwik doesn’t save my changes? I’ve deleted the FeedBurner widget for example. It’s still there as soon as I visit the dashboard again.
