Regex für haproxy
Da ich nirgends etwas gefunden habe, habe ich versucht mein eigenes Regex dafür zu schreiben:
Leider funktioniert dies nicht so wirklich und ich sehe aktuell nicht warum, hat noch jemand eine Idee?
[09:05 root@drupal-cms ~] > /var/www/piwik/misc/log-analytics/import_logs.py --recorders=4 --url=https://stats.promato.de --idsite=16 --log-format-regex='.*:\ (?P<ip>[\w*.]+).*\[(?P<date>.*)\].*\ (?P<status>\b\d{3}\b)\ (?P<length>\d+)\ -.*\"(?P<method>\S+)\ (?P<path>[\S]+).*' --dry-run /tmp/krberlin.log.1
0 lines parsed, 0 lines recorded, 0 records/sec (avg), 0 records/sec (current)
Parsing log /tmp/krberlin.log.1...
Logs import summary
    0 requests imported successfully
    22 requests were downloads
    4562 requests ignored:
        101 HTTP errors
        38 HTTP redirects
        2179 invalid log lines
        0 filtered log lines
        0 requests did not match any known site
        0 requests did not match any --hostname
        0 requests done by bots, search engines...
        2244 requests to static resources (css, js, images, ico, ttf...)
        0 requests to file downloads did not match any --download-extensions
Website import summary
    0 requests imported to 1 sites
        1 sites already existed
        0 sites were created:
    0 distinct hostnames did not match any existing site:
Performance summary
    Total time: 0 seconds
    Requests imported per second: 0.0 requests per second
Leider scheint es auch keine Methode zu geben mir sagen zu lassen welche Lines ihm nicht passen.
@Lukas Irgendeine Idee? Das zu debuggen ist echt frustrierend.
Alle diese 10 Zeilen sind angeblich ungültig, matchen aber das Regex:
Sep 25 05:55:57 dktig-proxy haproxy[6801]: 157.55.39.209:33372 [25/Sep/2018:05:55:57.211] ft_https~ bk_krberlin/dkv 0/0/0/208/208 200 8325 - - ---- 15/12/0/1/0 0/0 "GET /de/suche/search/berlin/bezirk/12.jsf HTTP/1.1"
Sep 25 06:02:55 dktig-proxy haproxy[6801]: 157.55.39.209:28324 [25/Sep/2018:06:02:55.349] ft_https~ bk_krberlin/dkv 0/0/0/277/277 200 7433 - - ---- 7/6/0/1/0 0/0 "GET /en/search/search/hospital/show.jsf HTTP/1.1"
Sep 25 06:05:01 dktig-proxy haproxy[6801]: 189.59.5.81:58370 [25/Sep/2018:06:05:01.688] ft_https~ bk_krberlin/dkv 0/0/1/103/104 200 7316 - - ---- 5/4/0/1/0 0/0 "GET /user/ HTTP/1.1"
Sep 25 06:05:27 dktig-proxy haproxy[6801]: 176.62.229.88:55008 [25/Sep/2018:06:05:27.584] ft_https~ bk_krberlin/dkv 0/0/0/72/72 200 7456 - - ---- 5/4/0/1/0 0/0 "POST /user/ HTTP/1.1"
Sep 25 06:21:59 dktig-proxy haproxy[6801]: 66.249.76.104:60671 [25/Sep/2018:06:21:58.960] ft_https~ bk_krberlin/dkv 0/0/0/277/277 200 7532 - - ---- 9/8/0/1/0 0/0 "GET /en/search/hospital/show/formular/2.1/261100310/00.jsf HTTP/1.1"
Sep 25 06:22:30 dktig-proxy haproxy[6801]: 157.55.39.114:11032 [25/Sep/2018:06:22:30.443] ft_https~ bk_krberlin/dkv 0/0/0/128/128 200 8643 - - ---- 7/6/0/1/0 0/0 "GET /de/hilfe/merkliste HTTP/1.1"
Sep 25 06:22:31 dktig-proxy haproxy[6801]: 157.55.39.114:11032 [25/Sep/2018:06:22:30.740] ft_https~ bk_krberlin/dkv 0/0/0/446/453 200 39206 - - ---- 7/6/0/1/0 0/0 "GET /de/suche/Struktur.html HTTP/1.1"
Sep 25 06:22:35 dktig-proxy haproxy[6801]: 157.55.39.197:7732 [25/Sep/2018:06:22:35.793] ft_https~ bk_krberlin/dkv 0/0/1/91/92 200 8052 - - ---- 7/6/0/1/0 0/0 "GET /de/hilfe/qualitaet HTTP/1.1"
Sep 25 06:23:18 dktig-proxy haproxy[6801]: 66.249.76.102:54478 [25/Sep/2018:06:23:17.934] ft_https~ bk_krberlin/dkv 0/0/0/509/509 200 8629 - - ---- 5/4/0/1/0 0/0 "GET /en/search/hospital/show/formular/2.1/261100310/00/314475953.jsf;jsessionid=8A79BAEFBBB2DC550D4ED403A98F7191 HTTP/1.1"
Sep 25 06:23:52 dktig-proxy haproxy[6801]: 66.249.76.102:54478 [25/Sep/2018:06:23:51.824] ft_https~ bk_krberlin/dkv 0/0/0/426/426 200 9763 - - ---- 6/5/0/1/0 0/0 "GET /en/search/hospital/show/formular/2.2/261110027/02/314429390/B-3:table1/3.html;jsessionid=86C4FDD3FB60F6677F05C8E8A4A73D03 HTTP/1.1"
Ok, habe es gelöst. Ich habe gelernt (Invalid log lines with common_complete log format · Issue #197 · matomo-org/matomo-log-analytics · GitHub), dass man 2x --debug angeben kann um angezeigt zu bekommen was ihn genau stört (Ist das irgendwo dokumentiert?). Danach war es recht einfach, man muss einfach ein Datumsformat angeben welches die Millisekunden enthält :smiley:
Um erfolgreich haproxy Logs zu importieren benötigt man also folgende 2 Optionen:
--log-format-regex='.*:\ (?P<ip>[\w*.]+).*\[(?P<date>.*)\].*\ (?P<status>\b\d{3}\b)\ (?P<length>\d+)\ -.*\"(?P<method>\S+)\ (?P<path>[\S]+).*' --log-date-format='%d/%b/%Y:%H:%M:%S.%f'
Schön, dass du die Lösung gefunden hast. Ich habe LogAnalytics noch nie verwendet und kenne mich daher nicht so gut aus.
Es wäre wirklich nett, wenn du einen Pull Request mit dem Regex machen könntet:
Das mit --debug --debug ist definitiv nicht intuitiv und kommt auf meine Dokumentations-TODO.
Puh, mein Python ist echt nicht so gut. Ich schaue mal ob ich das hinbekomme…
Ich glaube, du musst einfach nur hier einen Eintrag hinzufügen.
Tja, leider isses nicht so einfach. Wenn ich den Regex fest einbaue matcht plötzlich keine einzige Zeile mehr. Ich gucke mal ob ich was rausfinde.
Vermutlich brauchst du in Python die ganzen \ zum Escapen der Sonderzeichen (wie [) nicht mehr.
Der Regex Editor ist auf Python eingestellt UND natürlich wurde das Regex auch vorher mit Python gematched wenn ich über die CLI übergebe :wink:
Ok, habe das Problem gefunden in dem ich mir mal hab ausgeben lassen, was er an re.compile() übergibt. Es sieht so aus, also müsste ich \b doppelt escapen, also \\b dann kommt es korrekt als \b beim compile an.
