Is there a way to recognize if archiving was done or not?
Background of my question is that after upgrading to piwik 2.10.0 archiving seems to run ( at least I cant trigger error messages) but the output it produces is empty.
I use this method
http://your-server.org/path/to/piwik/misc/cron/archive.php?token_auth=XYZ
as explained in the user guide and it worked fine until 2.9.1
Now it seems to still run, but the output is empty. I can reproduce it on my local machine with a new piwik install.
Running it locally on my machine via commandline works fine, so I assume there is a problem with outputting the data.
Thanks for help.
