I’ve read the FAQs and users guides. Piwik is set up at http://stats.bytewriter.com. I’m trying to import logs from http://bytewriter.com. It apparently is reading the current stats from the day I installed it. If I try executing the command from the logs directory, even with the full path to import_logs
No matter which command I use, I either get the imports help file or I get a 0 import summary. If I use any of the command line switches it doesn;t seem to help.
python import_logs.py --url=stats.bytewriter.com --idsite=1 casite-638320.cloudaccess.net/logs/access.log
0 lines parsed, 0 lines recorded, 0 records/sec (avg), 0 records/sec (current)
File casite-638320.cloudaccess.net/logs/access.log does not exist
Logs import summary
0 requests imported successfully
0 requests were downloads
0 requests ignored:
0 HTTP errors
0 HTTP redirects
0 invalid log lines
0 requests did not match any known site
0 requests did not match any --hostname
0 requests done by bots, search engines...
0 requests to static resources (css, js, images, ico, ttf...)
0 requests to file downloads did not match any --download-extensions
Website import summary
0 requests imported to 1 sites
1 sites already existed
0 sites were created:
0 distinct hostnames did not match any existing site:
Performance summary
Total time: 0 seconds
Requests imported per
