Problems with Internet Explorer 11 (IE 11)
I have difficulties adding users in matomo while using Internet Explorer IE 11.
My entries are displayed over the labels, so I cannot read them clearly.
When entering data, the focus jumps to other fields (or to nowhere?), so it is also difficult to enter data. Matomo is 3.7.0.
I did clear tmp/assets and tmp/template_c with no change. I can’t find the “add user” form on demo.matomo.org, so I can’t cross check there. matomo’s built-in check reports fine.
No error in IE’s console log.
Any hints?
Thanks in advance, Mike
Whats your resolution?
screen resolution? pc monitor … 1680 x 1050.
I can confirm that there is an issue, will look into it.
This should be fixed in Matomo 3.8.0, please report back after the new version went through. :slight_smile:
Hello, and the update has already happened? I have a similar problem
No, 3.8.0 is not out yet, but will be released soon.
Try clearing the cache and updating IE to its latest version.
