While auto upgrading to 3.9.1 the upgrading process stopped showing a blank page with following error message in the first line:
Matomo encountered an error: Call to undefined method Piwik\Plugin\Manager::getPluginDirectory() (which lead to: Circular dependency detected while trying to resolve entry 'Piwik\Twig')
I called Matomo again (not reloading the page) and Matomo worked fine with the actual version. I don’t know, whether there may be some misfunction in the background. I don’t hope.
Nevertheless I wanted to send you this feedback. Berhaps this may be helpful.
Hi, I have exactly the same problem. I see probably bug in matomo/Manager.php at 3.x-dev · matomo-org/matomo · GitHub on line 450:
$corePluginsDir = PIWIK_INCLUDE_PATH . ‘plugins/’ . $pluginName;
it creates path like /path_to_webplugins/PluginName
It should be /path_to_web/plugins/PluginName
Correct code should be probably:
$corePluginsDir = rtrim(PIWIK_INCLUDE_PATH, ‘/’) . ‘/plugins/’ . $pluginName; as it is down on line 477.
Btw. why not to use directly that function self::getPluginsDirectory() ?
OK so what is the resolution to this time wasting issue?
