After swtching to step 1 I get this error:
escapeshellcmd() has been disabled for security reasons
in ‘/var/www/web1138/html/piwik/core/Piwik.php’ at the line 1352
#0 Piwik_ErrorHandler(2, escapeshellcmd() has been disabled for security reasons, /var/www/web1138/html/piwik/core/Piwik.php, 1352, Array ([sDir] => /var/www/web1138/html/piwik/core/Db,[sPattern] => *.php,[nFlags] => )) called at [(null):0]
#1 escapeshellcmd(/var/www/web1138/html/piwik/core/Db) called at [/var/www/web1138/html/piwik/core/Piwik.php:1352]
#2 Piwik::globr(/var/www/web1138/html/piwik/core/Db, *.php) called at [/var/www/web1138/html/piwik/core/Db.php:64]
#3 Piwik_Db::getAdapters() called at [/var/www/web1138/html/piwik/plugins/Installation/Controller.php:522]
#4 Piwik_Installation_Controller::getSystemInformation() called at [/var/www/web1138/html/piwik/plugins/Installation/Controller.php:81]
#5 Piwik_Installation_Controller->systemCheck() called at [/var/www/web1138/html/piwik/plugins/Installation/Installation.php:62]
#6 Piwik_Installation->dispatch(Piwik_Event_Notification Object ([_notificationName] => FrontController.NoConfigurationFile,[_notificationObject] => Exception Object ( => The configuration file /var/www/web1138/html/piwik/config/config.ini.php has not been found., => , => 0, => /var/www/web1138/html/piwik/core/Config.php, => 110, => Array ([0] => Array ([file] => /var/www/web1138/html/piwik/core/Piwik.php,[line] => 1574,[function] => init,[class] => Piwik_Config,[type] => ->,[args] => Array ()),[1] => Array ([file] => /var/www/web1138/html/piwik/core/FrontController.php,[line] => 202,[function] => createConfigObject,[class] => Piwik,[type] => ::,[args] => Array ()),[2] => Array ([file] => /var/www/web1138/html/piwik/index.php,[line] => 90,[function] => init,[class] => Piwik_FrontController,[type] => ->,[args] => Array ()))),[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0)) called at [(null):0]
#7 call_user_func_array(Array ([0] => Piwik_Installation Object ( => Piwik_Installation_Controller),[1] => dispatch), Array ([0] => Piwik_Event_Notification Object ([_notificationName] => FrontController.NoConfigurationFile,[_notificationObject] => Exception Object ( => The configuration file /var/www/web1138/html/piwik/config/config.ini.php has not been found., => , => 0, => /var/www/web1138/html/piwik/core/Config.php, => 110, => Array ([0] => Array ([file] => /var/www/web1138/html/piwik/core/Piwik.php,[line] => 1574,[function] => init,[class] => Piwik_Config,[type] => ->,[args] => Array ()),[1] => Array ([file] => /var/www/web1138/html/piwik/core/FrontController.php,[line] => 202,[function] => createConfigObject,[class] => Piwik,[type] => ::,[args] => Array ()),[2] => Array ([file] => /var/www/web1138/html/piwik/index.php,[line] => 90,[function] => init,[class] => Piwik_FrontController,[type] => ->,[args] => Array ()))),[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))) called at [/var/www/web1138/html/piwik/libs/Event/Dispatcher.php:213]
#8 Event_Dispatcher->addObserver(Array ([0] => Piwik_Installation Object ( => Piwik_Installation_Controller),[1] => dispatch), FrontController.NoConfigurationFile) called at [/var/www/web1138/html/piwik/core/PluginsManager.php:363]
#9 Piwik_PluginsManager->addPluginObservers(Piwik_Installation Object ( => Piwik_Installation_Controller)) called at [/var/www/web1138/html/piwik/core/PluginsManager.php:250]
#10 Piwik_PluginsManager->loadPlugins() called at [/var/www/web1138/html/piwik/core/PluginsManager.php:165]
#11 Piwik_PluginsManager->setPluginsToLoad(Array ([0] => CorePluginsAdmin,[1] => CoreAdminHome,[2] => CoreHome,[3] => API,[4] => Widgetize,[5] => LanguagesManager,[6] => Actions,[7] => Dashboard,[8] => Referers,[9] => UserSettings,[10] => UserCountry,[11] => VisitsSummary,[12] => VisitFrequency,[13] => VisitTime,[14] => VisitorInterest,[15] => ExampleAPI,[16] => ExamplePlugin,[17] => ExampleRssWidget,[18] => ExampleFeedburner,[19] => ExampleRssWidget,[20] => Provider,[21] => Feedback,[22] => Login,[23] => UsersManager,[24] => SitesManager,[25] => Installation)) called at [/var/www/web1138/html/piwik/core/FrontController.php:209]
#12 Piwik_FrontController->init() called at [/var/www/web1138/html/piwik/index.php:90]
What is wrong?
Greetings Peter
