I still read the documentation and user guide and I found nothing that helped me.
I installed Piwik in the directory http://reviewonlinesite.com/piwik/ just as written in the manual. In addition, the JavaScript code is generated automatically and then I think is right.
What do you mean when you write the code is wrong and also the piiwk is not installed in the right path?
Yes! This is the problem I am facing. My hosting provider has disabled the mod_security but I’m still running into this issue. Could someone please help me set this up?
Hey Matt! I posted on my other post that it’s now working. The issues were with the Bullet Proof Security Plugin! Maybe this should be made public somewhere that these two do not like to work with each other. Thanks again for all your help.
