Hi all
Maybe you will have ideas with my problem. I wrote some plugin, which uses its own db table. On view it’s simple table. When i click on column, out request with params
action=pageIntent
controllerActionCalledWhenRequestSubTable=
date=2013-04-15
enable_sort=1
filter_offset=0
filter_only_display_idgoal=-1
filter_sort_column=Index
idSite=104
module=UserProfiles
period=year
totalRows=100
viewDataTable=table
Response is returned with sorted table, it’s ok. But table on user brouser don’t change. In console js error ‘uncaught exception: Syntax error, unrecognized expression: #’. What could it be?
matthieu
(Matthieu Aubry)
May 25, 2013, 3:10am
#2
not sure, can you check the response has the right DIV id/classes (compared to the core ones) ?
We will definitely make this better/easier in Piwik 2.0 in next few months.
I looked my response and DIV (like
) is absent. Maybe you know any exampe, how to get sorted data via ajax.
I’m using this code:
function pageReport()
$view = Piwik_View::factory('index');
$view->profilesHeader = Piwik_Translate('tmpProfilesAdm_SubMenuNameIntent');
$objPageTable = Piwik_ViewDataTable::factory('table');
$objPageTable->init($this->pluginName, __FUNCTION__, "tmpProfiles.getReport");
$objPageTable->setSortedColumn('ID', 'asc');
$objPageTable->setLimit(200);
$objPageTable->disableShowAllColumns();
$objPageTable->disableExcludeLowPopulation();
$objPageTable->disableSearchBox();
$view->profilesTable = $this->renderView($objPageTable, true);
echo $view->render();
I did not understand in detail. In first version in controller used code like this
//call from client
function getPageReport()
//table
$view->profilesTable = $this->getPageTable('getReportUser', array(
'profile',
'visitors',
'Index'
function getPageTable($action, array $headers)
$objPageTable->init($this->pluginName, __FUNCTION__, "Report.".$action);
//table
$this->fTranslateHeaders($headers);
foreach($headers as $k => $header)
$objPageTable->setColumnTranslation('Column-'.$k, $header);
$objPageTable->setSortedColumn('1', 'asc');
return $this->renderView($objPageTable, true);
In second version using code like this
//Controller
//call from client
public function getPageInterest($fetch = false) {
$view = $this->getPageIntentView(__FUNCTION__, 'getEntryPageInterestSubDataTable');
$this->configureViewInterest($view);
$this->configureViewActions($view);
return $this->renderView($view, $fetch);
protected function getPageIntentView($currentAction, $controllerActionSubtable)
$view = Piwik_ViewDataTable::factory();
$view->init($this->pluginName,
$currentAction,
'Report.getReportIntent',
$controllerActionSubtable );
$view->setColumnTranslation('label', Piwik_Translate('Report_ColumnPageURL'));
return $view;
//API
public function getReportIntent($idSite, $period, $date, $segment = false, $columns = false)
try{
$result = Piwik_fetchAll("
SELECT
, array($idSite)
$this->fTranslateColumn($result, 'Interest');
catch(Exception $e){
$result = array();
$dataTable = $this->getReportTable($result);
return $dataTable;
public function getReportTable(&$data)
$dataTable = new Piwik_DataTable();
foreach($data as $row)
$dataRow = new Piwik_DataTable_Row();
$i = 0;
foreach($row as $column)
$dataRow->addColumn('Column-' . $i++, $column);
$dataTable->addRow($dataRow);
$dataRow->__destruct();
return $dataTable;
