Hey,
I’ve try to install piwik, but when I open the index.php i get following error message:
Warning: require_once(Zend/Session/Abstract.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/web4/html/scripte/piwik/libs/Zend/Session.php on line 28
Fatal error: require_once() [function.require]: Failed opening required 'Zend/Session/Abstract.php' (include_path='.') in /var/www/web4/html/scripte/piwik/libs/Zend/Session.php on line 28
the files Session.php and Abstract.php exist, what can I do?
