Nothing should have changed recently
From which version did you update?
Did you by chance disable the GeoIP2 plugin?
Can you re-configure the geolocation in the admin settings?
Thanks for the feedback. I now see that I am missing the necessary file in misc/ . I initially though that this method was no longer supported by Matomo. My fault
