Hello.
I’m testing Heatmaps and Session recordings plugin and I encountered weird problems.
All requests to configs.php file end up with blank page and 200 OK response. Nothing is recorded. I checked the configs.php file and empty GET request to this file should return 400 Bad Request code but I still get 200 OK responses even with empty GET requests.
It seems that something is blocking the plugin.
That website uses Nginx. I wonder if X- headers can do something with blocking the plugin. Tested website has X Content Type set to nosniff, X-Frame-Options to Deny and XSS Protection to 1;mode=block. Unfortunately I can’t request any change to headers on that website unless I have solid proof.
Is there anything else what can block this plugin?
EDIT:
Thanks for moving my post to correct category. Anyway, here’s also a message from system check(I removed website address). I forgot to include it:
We couldn't check if 'https://(......)/plugins/HeatmapSessionRecording/configs.php?idsite=1&trackerid=5lX6EM&url=http%3A%2F%2Ftest.test%2F' is accessible over the Internet or Intranet.Please open the URL manually in a browser to see if the response contains 'Piwik.HeatmapSessionRecording'. If not, you might need to modify your server configuration as this file needs to be accessible via a browser from the Internet or Intranet.
