Amin
(amal)
May 14, 2017, 2:04pm
#1
hi
I’m running litespeed and I had no problem with http protocol, until I applied https for all my magento store pages.
there is something wrong with my root .htaccess file because removing file will solve the problem.
error is: Oops… there was a problem during the request. Maybe the server had a temporary issue, or maybe you requested a report with too much data. Please try again.
but I could not find any error in error-log
also here is my htaccess code I use:
################## Creare's Magento .htaccess File #################
############ https://github.com/Creare/magento-htaccess ############
### Prevent sftp-config.json from being loaded:
<files sftp-config.json>
order allow,deny
deny from all
</files>
### Protect .htaccess
<Files ~ "^.*\.([Hh][Tt][Aa])">
order allow,deny
deny from all
satisfy all
</Files>
##### Recognise SSL when set at a load balancer/proxy level (for CloudFlare) #####
This file has been truncated. show original
please someone help what should i do to!?
Lukas
(Lukas Winkler)
May 17, 2017, 2:59pm
#2
What does your problem have to do with piwik? Which request is returning Oops… there was a problem during the request
Amin
(amal)
May 17, 2017, 3:14pm
#3
hi Findus23,
I have found piwik has problem with this lines:
RewriteCond %{REQUEST_URI} !(downloader) [NC]
RewriteCond %{THE_REQUEST} ^./index.php
RewriteRule ^(. )index.php$ http://www.yourdomain.com/$1 [R=301,L]
I disabled them an now piwik is running well
Lukas
(Lukas Winkler)
May 17, 2017, 3:17pm
#4
If I understand correctly those lines rewrite every request to the index.php of magento, so they newer end up at piwik.
Amin
(amal)
May 17, 2017, 3:27pm
#5
I’m not expert in this case, I don’t know exactly
