i have a problem with my piwik.
I tried to update my piwik from 0.4.5 to 0.5.5. and got the message “Database upgrade necessary”. I clicked the “upgrade piwik” button and got the message “piwik has been updated”.
BUT when i go back to the piwik start page the statistics are not shown properly.
I get the message (translated from german: Lade Daten… Oops… es ist ein Problem während der Anfrage aufgetreten, bitte noch einmal versuchen.): “Loading data… oops…an error has occured during the query, please try again.”
I have reset the “version_core” back to “0.4.5” in the “piwik_option” table and tried to update again. Also without success.
I dont have an idea what to do now.
Can you give me a hint?
The automated update was inadvertently broken in 0.4.4 and 0.4.5. If you are running either of these versions, please update manually to 0.5 and beyond.
no css is loaded, so its only plain text with links shown.
the database upgrade seams to be done successfull,
im a little bit angry about that, every time in the past it works…
but the whole software is a huge success.
"Dashboard All Websites Widgets API
Hallo, XXX! | Einstellungen | Webseite XXX.de Site
| Abmelden
Piwik 0.5.5 ist ein gemeinschaftliches Projekt.
Wenn Ihnen Piwik gefällt, können Sie helfen! Möchten Sie herausfinden wie Sie zu Piwik beitragen können? Piwik Sonntag 4 April 2010 - Tag | Woche | Monat | Jahr
Lade Daten…
Oops… es ist ein Problem während der Anfrage aufgetreten, bitte noch einmal versuchen."
i hope someone can tell me whats to do.
i could try to upload a fresh version to the server tomorrow.
It sounds like your webserver doesn’t like the .htaccess files added in 0.5.5. Check your Apache configuration… do you have “AllowOverride None” or “AllowOverride -Limit”?
In themes/.htaccess, plugins/.htaccess, and libs/.htaccess, can you try removing the line:
[quote=vipsoft @ Apr 5 2010, 09:36 PM]It sounds like your webserver doesn’t like the .htaccess files added in 0.5.5. Check your Apache configuration… do you have “AllowOverride None” or “AllowOverride -Limit”?
Order Deny,Allow
???[/quote]
Thanks for the fast answer.
there was a problem with the permissions, so the apache-server had no rights to read the .htaccess files.
by taking this to 644 all works fine.
Hello davidak.
That sounds interesting. Its just the same error-message i got.
Can you tell me where this .htaccess-file is located.
In the “root”-directory of piwik i have no .htaccess-file but in the “config”, the “core”, the “js”, the “lang”, the “libs”, the “misc” (called “.htaccess_to_use_later”), the “plugin” and the “themes” directory.
The problem is: i dont know which htaccess-file they were talking about!!! style_emoticons/<#EMO_DIR#>/huh.gif
I have no htaccess-file in the root directory of piwik.
Same here, just as the previous poster, except the apache config edit since I do not know how to access the file (I am on a commercial hoster).
I do not feel very comfortable with deleting the htaccess files, though that seems the only way piwik works since 0.5.5… style_emoticons/<#EMO_DIR#>/angry.gif
Anthon, could we delete these .htaccess? AFAIK they are not mandatory and don’t necessarily help with security (piwik files, accessed directly, can never execute and do something). thoughts?
.htaccess files are generated by the installer and no longer included in the packaged release; so if you had to delete the .htaccess files to make Piwik work, these files won’t re-appear when you auto-update
if you unpack the release on your desktop and then ftp the files to your server, you won’t be transferring any .htaccess files – avoiding the permissions issue
I’ve also changed the content of the .htaccess files; a file containing simply “Deny from all” doesn’t actually work (oops)
finally, I tested with AllowOverride None vs All, and Order deny,allow vs allow,deny
Note: if you have AllowOverride None, the .htaccess files are ignored.
