I’m having problems updating the version of the Matomo installation I have on a server. I perform the procedure that is documented step by step:
Make backup of the database and files
Put in maintenance mode and disable the log tracker
Copy the Matomo 4.1.1 files in the path
Launch Matomo update by command line: php console core: update
In this step, I get the error that I have to correct as the screenshot shows. I delete that file and run the update process again.
After finishing the update process, it throws me the following message with the following error:[X] Error during plugin updates:
/var/www/educacion/cau_ce/estadisticasweb/core/Columns/Updater.php:
Error trying to execute the migration ‘ALTER TABLEpiwik_log_visit
MODIFY COLUMNvisitor_count_visits
INT(11) UNSIGNED NOT NULL DEFAULT 0, MODIFY COLUMNvisit_total_interactions
MEDIUMINT UNSIGNED DEFAULT 0, MODIFY COLUMNreferer_name
VARCHAR(255) NULL, MODIFY COLUMNreferer_url
VARCHAR(1500) NULL, MODIFY COLUMNconfig_browser_name
VARCHAR(40) NULL, ADD COLUMNconfig_client_type
TINYINT( 1 ) NULL DEFAULT NULL, MODIFY COLUMNlocation_region
char(3) DEFAULT NULL, MODIFY COLUMNlocation_region
char(3) DEFAULT NULL;’.
The error was: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘location_region’ in ‘piwik_log_visit’ -
The update completed successfuly, however there were issues during the process. Please read the above descriptions for details. For further help: -
Check the [ Matomo FAQ ] which explains most common errors during update.
Ask your system administrator - they may be able to help you with the error which is most likely related to your server or MySQL setup.
Matomo has been successfully updated!
It appears you have executed this update with user root:root, while your Matomo files are owned by apache:apache.
To ensure that the Matomo files are readable by the correct user, you may need to run the following command (or a similar command depending on your server configuration):
I can’t continue and it stays on that page that is still waiting for updates in the database.
I had to revert to the previous version to detect why it is giving that failure in the update.
Any idea why this bug?
Kind regards
