Problem after Installation - Unable to read resource
i tried to install Piwik 0.8, 0.9 and 1.0 but with every version I have the same problem:
The installation process works, but after Piwik told me, that it got installed, trying to navigate to it’S URL brings the following error:
unable to read resource: “/hosting/data/myc:www/www/piwik/plugins/Login/templates/login.tpl”
The stated file and path are correct, the file exists:
$ ls -l /hosting/data/myc:www/www/piwik/plugins/Login/templates/login.tpl
-rw-r–r-- 1 root wheel 1283 Apr 2 22:03 /hosting/data/myc:www/www/piwik/plugins/Login/templates/login.tpl
Who can help?
Thanks & Greetings,
David Brueckmann
Hmm… I haven’t seen this error before. It’s occuring in the Smarty library that we use. The installer uses Smarty templates too, so if you got that far, I see no reason why it should be failing now.
Try adding some debugging messages to libs/Smarty/Smarty.class.php.
I found the problem… we used a colon in our path and that caused this error. Renamed the path - it works.
