Hi folks,
is it possible to use pk_campaign as an post instead of an get parameter?
It would be useful after Clean URL redirects.
example
http://example.org/mailing
http://example.org/offer.html?pk_campaign=mailing
greetz
klml
Hi folks,
example
greetz
klml
It should work yes.
Hi Matt,
thanks for your reply. Unfortunately it seems that it doesn’t work
I tried this 2 similar forms
send
this works
send
this not
but no big problem. get is still ok for me
greetz
klml
Actually you are right, I just checked the code, it only works when in the URL.
