Hi guys,
I was trying to setup piwik 0.41 on my company’s Solaris10 server with MySQL5.1.37 + PHP5.2.9 + Apache2.0.59.
However, I met a really weird error which takes me very long time to investigate but still did not get solved - when installing piwik 0.41, first 5 steps work fine (you can check the installation guide via link below), on step06 apache throws error: “[notice] child pid 3733 exit signal Segmentation fault (11), possible coredump in /export/home/apache2”, and browser shows “page cannot be displayed”
http://piwik.org/docs/installation/
Our current apache is version 2.0.59, I also tried 2.2.12, still the same error. And I tried different Mysql versions and PHP versions, got same error.
Any suggestion on resolving the problem is really appreciated!
Thanks,
Alfred
PS. phpinfo page is attached for your diagnosis.
